| Message |
Im in need of some help guys, I just got my 120k timing belt kit put on while i was finishing up school and on the first start up i got a CEL that said my injector circuit is bad. With the timing belt, i also replaced the injector harnesses but it turns out the connectors on the injectors themselves are corroded and bad. Is there anything i can do short of changing injectors? I already tried baking soda and using files with dialectric grease. Question number two, if i have to change injectors, im gonna buy bernies kit to change over to new style, anything else i should replace if the plenum is off? is the tb coolant line delete worth it?
